Learning VB 2015 in a different way and getting all details
10 points
Posted on - 04/09/2015
Hi!
Is there any tool that I can use to interact with other Windows applications? What are the tools that I can use to access directories? I want to make an organized application, what are the tools I can used to organize or group the objects in my form? What is the difference between textbox and label? Can change the value of label at real-time? What is the use of timers in tool box? What is the best way to use it? What are the properties I can use to animate command buttons? Your answer is much appreciated! Thank you!
