I am just new to computer programming and wanted to know more about Visual Basic 2015. What are the system requirements for this software to be installed? Can you tell me anything about the environment or platform of this software? What is the difference between Visual Basic 6.0 and 2015? What are the added new features in visual basic? What is the meaning of UDI? What is the meaning of IDE? Please help me.
Learning Visual Basic 6.0 and 2015 and what are the specifications?
Hello Amanda!
It is not UDI it is supposed to be IDE (Integrated Development Environment). This is the best feature in VB and its versions. It has the ability to show the programmer or user to navigate easily with the platform of VB. The difference with VB 6.0 (classic) and VB 2015 or earlier version is that it constructs the program using “Class”. Class is an extensive program code template to create objects or controls in VB. Additional controls where added to VB 2015. You can now create applications for smart phones. As of this moment, Microsoft haven’t revealed the system requirements of VB2015. Please be aware that it will require great capacity of your hard disk, memory and processor. In VB2013 version, it required 1.6 Ghz process or higher than that to maintain smooth processing especially with graphics.
