I am using Windows 2000 Advanced Server and recently I have all of my clients disconnected. So to get rid of it I reboot the system and then I get this message:
Service Central Manager
“At least one service or driver failed during system startup…..". What service or driver is talking about in this message? What should I do now?
Thanks in advance.
This problem occurs when you do not configure the Microsoft networks for clients. So first complete this process and then reboot the system.
1. Click the start button and go to Settings.
2. Locate the Network and dial-up connections and click on local area network.
3. Then on the dialog box that appears, click install.
4. After the installation is completed, click add clients and add client for microsoft networks. Click ok and restart your system.
Hope this information helps you.
