Hi fellas,
I already have a Manycam driver and it is installed on my netbook, but I want also to install lego webcam driver. Does it complicate with the previous driver or I should only use one webcam driver? which of the two is the best driver?
Is lego web camera driver compatible to any webcam device?
If your webcam is working accurately you don't need to install any other driver. You didn't mention about the webcam you are using currently. It is preferred to install the drivers provided by the webcam manufacturer. Usually one webcam drivers are compatible with many webcams.
And yes webcam drivers with multiple manufacturers on same machine can cause complications. However if you are facing some problem with the already installed drivers, please uninstall the drivers and install the new one.
I hope this will help.
