monique027
Posted on - 11/18/2012
I just bought a Lenovo Thinkpad x1 Carbon and I added a lenovo active wallpapers windows 7 on it. After a few days has passed, the screen just went black. I tried restoring the active wallpapers back but it just wouldn’t. It would show up for a few moments then would return to the same black screen as before. Can anybody help me with this?  I just bought a Lenovo Thinkpad x1 Carbon and I added a lenovo active wallpapers windows 7 on it. After a few days has passed, the screen just went black. I tried restoring the active wallpapers back but it just wouldn’t. It would show up for a few moments then would return to the same black screen as before. Can anybody help me with this? Â
Lenovo active wallpapers windows 7 problem
The main reason for your problem is the issue of not using Original Microsoft Windows or your copy is still not registered. To get this issue resolved, try buying the original windows from Microsoft or if you have an original one then register it online using the Product ID key that has been provided along with your Windows DVD on purchase.Â
Good day Monique,
After a long research about your lenovo thinkpad x1 carbon screen just went black, i did not find any solution.
But here is my suggestion to you. I assume that there still a warranty in your lenovo thinkpad carbon.
I suggest you bring your thinkpad to where you bought it and let them fix or replace your thinkpad. I think it is much better that way than to void their warranty by doing something onto it. hope this helps. thank you and god bless.Â
