Lenovo desktop shortcut to connect external monitor or projector
Hi friends, I would like to know if there is any lenovo desktop shortcut that will connect my system to external monitor or projector
Hi,Â
There are two ways to connect your Lenovo to external projector or monitor. Here is the instruction please follow it.
1. Press F7 key to connect to a projector. It's a shortcut if it doesn't work follow these steps.
2. Open the control panel and the Intel graphic.
3. You can access from 3 places.
A). You can access from the tray by clicking on the blue monitor icon.
B). Right click on the desktop and go to the Graphic option.
C). From control panel open Intel graphic
4. Choose the option of clone monitor.
Simple and easy.
