I own a Lenovo g450 laptop. I plugged in my laptop for charging the previous day and left for a while. On return home, I found Lenovo g450 battery not charging. At first, I thought I had forgotten to turn the switch on but no. The switch was on and yet, the laptop refused to charge. How to solve this issue?
Lenovo G450 Battery Not Charging What To Do
Regardless of what brand’s laptop you are using, after a little while, when it starts to get older, such things can happen sometimes. Try to plug-out and plug-in the charger once again. In many cases, simply plugging and unplugging the charger does the trick.
If this does not solve your problem, you might want to reset your computer. To do this, remove the battery from your computer. Let it sit idle for about 30 seconds. Attach the battery back to your computer. Try charging the laptop now. It should work just fine. If even this does not work, try another charger or call your customer service.
