Buying a Lenovo g550 feels like the biggest mistake of my life. It is brand new. I expected it to be flawless. All the excitement blew away when I found my Lenovo g550 USB ports not working. Can this be fixed or do I have to return the brand new laptop I just bought?
Lenovo G550 USB Ports Not Working
There are a few reasons as to why the USB ports on your Lenovo device may not work. The problem may be a software or a hardware problem. If it is a software problem, then it can be dealt with at home. If it is a hardware problem, then I’m afraid you’ll have to take that to the retailer.
One of the easiest ways to resolve this issue is to shut down your laptop. Remove the battery, wait for about 30 seconds and then reconnect the battery. Turn on your laptop, and you should be fine.
If this fails, you should go into your system bios and check if the USB ports are enabled. If not, then enable them, and you are good to go. If none of these work, then I am afraid it’s a hardware issue.
