Is Lenovo ideacentre a310 dependable?
Would a Lenovo ideacentre a310 be an alternative to MAC?  I'm thinking of buying 21.5 inch Lenovo Ideacentre a310 with Intel Core i3 2.4 GHz, 4 G RAM, 500 G HDD and Intel HD Graphics card.  Lenovo would be much cheaper than a Mac but would it also be dependable?
Answered By 0 points N/A #164156
Hello Marie,
Whether a Lenovo will be reliable for you actually depends on what purpose you want to buy the laptop for. If you are a basic PC user, you may like to buy Mac as the Operating System in Mac is simple and user-friendly and will help you operate easily. However, if you are much of an advanced user who likes to play games and develop software, Lenovo will be better for you as it has WIndows OS installed by default and it supports a wide range of software and application, not to mention the hardware configuration. So choosing between these two is entirely up to you.
Regards
