Hi Friends,
I am using Windows 7 in my Lenovo Notebook Z460, and there seem to be sound related issues due to missing of its related driver, Please help me to get Lenovo Notebook Z460 Audio drivers for Windows 7 by providing a download link towards it.
Thanks,
Ashley Glick
Notebook drivers for a specific brand are almost the same. The drivers versions are more often updated for different versions of the notebook or laptop. You can always do the searchings related with your specified brand. But suggestion is that you can install any audion driver for your Lenovo Notebook Z460. Below the link shows you some specific solutions for downloading the drivers.
https://driverscollection.com/?H=IdeaPad%20Z460&By=Lenovo
The best way and more efficient way for this fix is going online to the manufacturer´s website and downloading it from there specifically. You need to choose the category, in your case it would be audio, then the OS that you have Windows 7! You´ll have the installation file to download! Download it and then install! There´s practically no way you can go wrong with this!
Here´s the link of the driver you need! http://www.notebook-driver.com/lenovo-ideapad-z460-windows-drivers-software/
Let me know if you need anymore help!
Hey Mr. Glick,
Sometimes the problem is caused due to some minor changes made in the default settings. You can try troubleshooting the problem with your audio devices.
If you have already tried it and it doesn’t work then you can find the required drivers for your Lenovo Z460 that may be compatible with windows 7- both 32 and 64 bit systems – available for direct download at the following link:
http://download.lenovo.com/UserFiles/Driver/en/Downloads%20and%20Drivers/Z460Z560/IN2AUD34WW5.exe
