Let me know about ASUS Xonar Essence STX sound card
What is the port version of Xonar Essence STX? Can I use a home theater system, headphones and speaker set with this port? What is the main feature, it has? Please describe about Audio Performance. Which operating system is required? Which Accessories are available in Xonar Essence STX sound card? What is Magic Voice system? Thank You
Answered By 0 points N/A #200343
Hello Aditya!
Here are the answer to your questions.
1. What is the port version of Xonar Essence STX? Answer – the port version of this sound is PCI 1.0 or higher, for the I/O ports 6.30 mm for headphone and for RCA jack, S/PDIF port, Aux-In 4 pin header.
2. Can I use a home theater system, headphones and speaker set with this port? Answer – you can use SPDIF connector to utilize your home theatre system with this sound card.
3. What is the main feature, it has? Answer the main feature it has will be VOCALFX( for VoIp and games), noise eliminator and Magic Voice, normalizes the volume of all audio files, karaoke functions, Xear 3D, Flex Bass, 10 Band equalizer, Direct Sound and Dolby Digital
4. Please describe about Audio Performance.
5. Which operating system is required? Answer – compatible PCI 1.0 slot or higher, MS Vista (32-64 bit), Windows XP (32-64 Bit), MCE 2005, Intel Pentium 4 1.4 Ghz or AMD Athlon 1400 CPU, 256 MB DRAM, 60 MB HDD, CD/DVD ROM.
6. Which Accessories are available in Xonar Essence STX sound card? Answer – accessories available with the package are 3.5mm to RCA cable (1pc.), 3.5mm to 6.3 mm adapter (1pc.), S/PDIF Toslink optical adapter (1pc.), Support CD.
7. What is Magic Voice system? Answer – Magic Voice System enables the user to change their voice. It is like disguising your voice or changing the pitch tone of your voice.
