How is the capacity of storage in it? What is UASP Mode? Is it compatible with USB 3.0, 2.0? What is 3D Vertical NAND technology and how does this work? If I forget my password then how can I find the password or retrieve data? Is there any LED indicator? How does AES 256-bit encryption work? Is it compatible with Mac operating system? Why is expat needed? How is SSD T1 data transfer speed? What is RoHS Compliance? Thank You
Let me know about Samsung Portable SSD T1
The Samsung portable SSD T1, such a stylish portable  SSD, It capacity varies according to the configuration you buy it in, You can get it in 250GB / 500GB / 1TB capacities, The UASP mode helps to boost the performance of the SSD up to 450MB/s, The 3D Vertical breaks free of the scaling limit for existing NAND Flash technology. Samsung has developed a new structure through its first 24-layer V-NAND, You shouldn't forget the password at all, If you did, You would have to factory reset the SSD, And loose all of your data, The portable SSD supports Mac, Its speed as i mentioned before, Is 450MB/s, Its RoHS tpe is RoHS2.
