I have a Google blogspot. How can I let my viewers to subscribe to my blogs or follow my blogs? How can I set it up so I can allow my viewers to subscribe to it? I am kind of new to this so I really need a step-by-step help. Thanks a lot!
Let my viewers subscribe to my Google Blogspot
Hey Leslie Woods,
Blogger is a web based tool to share and update the media/text or audio or anything a blogger likes. It is used by millions of users to share their posts and activities through their website usually hosted on the subdomains of blogspot.com. Now, If you want your visitors/viewers to keep in touch with you updates and subscribe to your website then you should consider doing the following steps:
Login to you blogger account by going to https://www.blogger.com/about/?r=1-null_user
Go to design template of your blog
Now click on “Add a gadget” where you want to place your “Follow” button. (Normally, it should be placed on the right side of the blog post.
A new window will appear and you may now click on the Plus button placed on the right side of “Follow by Email”
If you want your viewers to follow your blog via Google Friend Connect, you should select the button “Join This Site”.
You can also put both of these buttons by pressing the add a gadget button twice.
Thanks
Previous comment has showed you how to create your blog. Since you are new to blogging I’ll tell you some tricks to earn some money by blogging. After creating your blog login to your Google adsense account using you Google user credentials. From there you’ll be able to get some ad banners. Post those banners on your blog. Every time a user clicks on a ad on you blog google will credit some money to your adsense account. Remember to update your blog regularly so that you can increase the traffic to your blog.
