Hello!
I would like to know more about Air2 floating Bluetooth speaker. How much will cost? What is the purpose of levitating this speaker? If it is a magnet that makes this float, isn’t the magnet is affecting the quality of sound? How many speakers included? Is there any port available to connect it to power sockets or usb cord? Is it Bluetooth? Is it battery operated device? What is the highest floating distance for this speaker to levitate?
Levitating Bluetooth Speaker and Benefits of Using it
Hello Debra!
This speaker is a piece of technology that we can say it uses simple Science 101 idea.
1. The amount you have to spend for this amazing technology is now $200 in Amazon.com
2. The purpose of levitating the speaker genuinely for uniqueness.
3. The magnet between the speaker and the base doesn’t affect the sound quality at all. The levitation gap controls the magnets feedback to the speaker.
4. It connects using Bluetooth and USB port and cord that makes it easier to be accessed.
5. Yes! The battery life of this speaker can only maintain up to maximum or approximately 5 hours
6. It can only levitate of approximately 1.5-3 cm only.
