I want to take print of my documents by using iPad. For that purpose, I need Lexmark impact driver. I download Lexmark from internet but after installation, it occur uncertain error. Please if any body know about Lexmark Impact download for I pad then tell me, or give me working URL of that device so that it can fix my problem.
Lexmark Impact download for iPad
Hi Leslie Joshuaa,
You can download Lexmark impact driver here, then install this to your mobile device. But of course you must also have listener application in your computer if your printer does not belong to this printer list.
Make sure your mobile device is connected to the same wireless network as the computer you use to print because LexPrint requires that all your devices be connected to the same wireless network.
If you want to know about the software then you will find details in the link. The information is very wide in this link. Before doing anything you need to know about that. There can be a problem in the software so you can download that.Â
Thank you.
