LG 550 mobile software problem
Good day,
Good day,
Greetings,
Hi Juliana,
I have some suggestion and also looking forward to help and answer your question. As I read your question regarding connecting of your mobile LG 550 into computer to tell you the truth you must have a CD software to be install in your computer to connect your mobile using USB without this your mobile will not be compatible in you pc.
You can also ask your Cell phone provider about CD software if its free and you can buy and also for assistance. I have also suggestion you can also connect LG 550 via Bluetooth but take note you must buy also a device for Bluetooth and install in your pc. You can buy this at PC hardware on your place and also ask a guide in technician for installation if you don't know.
I hope it will work for you and help to answer your problem.
No. All the handsets don't come with the CDs always. Sometimes the software remains built-in the handset. You connect the handset with your laptop and then install the software in your laptop. Then you will be able to operate your handset through your Laptop.
But if the software is not built-in, then it must require a Software CD. If you do not have Software CD, your alternative way is INTERNET. Just search online by your handset model no. for your software installation CD. You will find the compatible softwares for your handset. Just download and install it.
There are many 550 models on LG phones and here’s one, the LG Stylus 2 Plus. The LG Stylus 2 Plus is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, HSPA, and LTE technologies. It was announced to the public on May 2016 and released on July 2016 measuring 155 x 79.6 x 7.4 millimeters and weighing 146 grams.
It uses nano-SIM card and available in single SIM and dual SIM. It has IPS LCD capacitive touchscreen display with 16M colors at 1080 x 1920 pixels screen resolution. It is protected with Corning Gorilla Glass 3 and includes a stylus.
It ships with Android 6.0 Marshmallow upgradable to Android 7.0 Nougat powered by 28 nm Qualcomm MSM8937 Snapdragon 430 chipset, either 1.2 GHz or 1.4 GHz Octa-Core Cortex-A53 processor, and Adreno 505 GPU. It supports microSDXC. It runs on the following memory and storage capacities:
The primary camera supports either 13 or 16 megapixels featuring f/2.2 and AF with LED flash and panorama. It supports 1080p video recording at 30 fps. The secondary camera supports either 5 or 8 megapixels with LED flash.
It has 3.5-millimeter jack, Wi-Fi 802.11 b/g/n with Wi-Fi Direct and hotspot support, Bluetooth 4.1 or 4.2 with A2DP and LE support, GPS with A-GPS and GLONASS support, NFC, FM radio, and microUSB 2.0. It has built-in rear-mounted fingerprint (region dependent), accelerometer, proximity, and compass sensors.
It runs on removable Li-Ion 2900 or 3000 mAh battery with standby time up to 315 hours on 3G and talk time up to 7 hours 30 minutes on 3G. It is available in titan, gold, and brown colors. Now, if you need to connect your phone to your computer, download the LG PC Suite.
