Werner Rowe
Posted on - 01/16/2012
Is LG 550 pretend to be like a software? I was attempting to access it to my computer but the problem is I do not have any Compact Disks (CD). Is this an error or do I need to buy another device individually?
If that is the first time that you are using the LG 550 device on your computer, then it may be installing the device drivers that will make it usable to that computer. And therefore you do not have to be worried that the device is behaving like a software. Once the device drivers have been installed, you will be able to access the device as usual without any problem. In fact if you unplug it and then plug it back to the computer, if the device drivers installed successfully, then you will not see that process happening again. So when you are asked to install the drivers, do not cancel, for they are crucial for the performance of the device.
-Chalk Talk
