LG G2 phone doesn’t connect to mobile data
Since the last update, my LG G2 phone has problems connecting to mobile data networks. Normally, it would connect automatically as soon as I lost a viable WiFi signal. Now it doesn’t, even when I see the mobile data network paired with the full signal icon.
Is there some solution or setting variation I can try to solve this issue?
Answered By 590495 points N/A #159398
The LG G2 handset is available for AT&T as LG G2 D800, for Europe as LG G2 D802, for Australia as LG G2 D802TA, for Canada as LG G2 D803, for Verizon as LG G2 VS980, and for Sprint as LG G2 LS980. The LG G2 handset model supports 2G, 3G, and 4G networks and uses a micro-SIM card.
This model was announced on August 2013 and released on September 2013. It measures 138.5 x 70.9 x 8.9 millimeters and weighs 143 grams. It has True HD-IPS + LCD capacitive touchscreen display with 16 million colors at 1080 x 1920 pixels screen resolution. It supports multi-touch and protected by Corning Gorilla Glass 2.
It is available in 16 and 32 GB internal storage capacities running on 2 GB RAM. The primary camera supports 13 megapixels at 4160 x 3120 pixels resolution with LED flash, autofocus, and optical image stabilization. It features face detection, real-time video and image recording, HDR, and geo-tagging. It can do video recording in 1080p at 60 fps with optical stabilization, HDR, and stereo sound recording.
The secondary camera supports 2.1 megapixels and can record video in 1080p at 30 fps. It runs on Android 4.2.2 Jelly Bean upgradable to 4.4.2 KitKat powered by Qualcomm MSM8974 Snapdragon 800 chipset on Quad Core 2.26 GHz Krait 400 processor and Adreno 330 GPU. It supports HTML5 for internet browsing and Java.
It runs on non-removable Li-Po 3000 mAh battery with standby time up to 790 hours on 2G and 900 hours on 3G while talk time is up to 16 hours and 30 minutes on 2G and 17 hours and 30 minutes on 3G. If you have a problem connecting your phone to the mobile network even if the data connection is already turned on, try restarting your handset.
If it doesn’t work, completely drain the battery by playing games. If the phone no longer opens because of an empty battery, wait for about 5 to 10 minutes before recharging. When charging it, make sure it is turned off so no battery is wasted. When the battery is fully charged, start the phone.
Make sure the Wi-Fi connection is turned off and the data connection is turned on. Start the web browser and see if you can open a website. If there is still a problem, go to the data connection then turn it off and then turn it on again. Try it again afterwards.
