LG optimus 3D Max doubts
I want to know some technical details about LG's new phone Optimus 3D Max. I want to know about its 3D mode performance. And also about its 3D software and clock speed.
Thank you in advance, have a nice day.
Answered By 0 points N/A #138119
LG Optimus 3D MAX is the second edition of the world's first 3D phone announced – the Optimus 3D â€“ and it is more of a refresh than anything else.
It feels pretty solid in the hand, as it's not very thin nor light, and the palm grip is improved by the patterned back, which has a slight hump at the bottom where the speaker grill is. Two 5 MP cameras with LED flash in the middle are the crown jewel of the Optimus 3D MAX, as they serve the third dimension to your pictures and video.
The front is in glossy piano black, but what adds more style to the phone are the side buttons and ports – made of metal, like on the LG Prada 3, they exude more premium feeling, and the sliding lid over the micro USB port on the left is a nice and comfortable to use idea. All keys are easy to feel and press, with good tactile feedback. There is a dedicated button on the right to launch directly the 3D content carousel, and switch the screen into 3D mode.
The 3D MAX it is a bit heavy mid-range device with run-of-the mill dual-core processor and WVGA screen resolution. On top of that it takes mediocre pictures, regardless if 2D or 3D, and has a substandard battery life when it comes to talk time.
However, we do have the 3D aspect, plus the phone has received a spec bump compared to its predecessor, sports a good call quality, and has a thing going for it designwise with the metal buttons and port lids. Thus if you are into the whole 3D thing, the LG Optimus 3D MAX is a decent choice.
  • The software will apply right over 2.3.4 GRJ22.
  • The new Optimus 3D MAX is offered with higher processor clock speed and 1 GB of RAM.
Thank you.
Answered By 590495 points N/A #311347
The LG Optimus 3D Max P720 is a discontinued 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was unveiled to the public on February 2012 and released on May 2012 measuring 126.8 x 67.4 x 9.6 millimeters and weighing 148 grams. It uses mini-SIM card. It has 3D LCD capacitive touchscreen display with 16M colors at 480 x 800 pixels screen resolution.
It is protected with Corning Gorilla Glass 2 with LG 3D UI. It runs on Android 2.3 Gingerbread with planned upgrade to Android 4.0 Ice Cream Sandwich powered by TI OMAP 4430 chipset, 1.2 GHz Dual-Core Cortex-A9 processor, and PowerVR SGX540 GPU. It supports microSD expandable up to 32 GB. It runs on 1 GB RAM with 8 GB internal storage (5.3 GB user available).
The primary camera supports 5 megapixels with AF and LED flash and supports 1080p video recording at 30 fps (2D) and 720p at 30 fps (3D). It has a secondary camera with VGA support.
It has 3.5-millimeter jack, Wi-Fi 802.11 b/g/n with DLNA and hotspot support, Bluetooth 3.0 with A2DP and EDR support, GPS with A-GPS support, NFC, stereo FM radio with RDS support, and microUSB 2.0 with MHL TV-out support. It has built-in accelerometer, gyro, proximity, and compass sensors. The pre-installed web browser supports HTML5 with Adobe Flash support.
It runs on removable Li-Ion 1520 mAh battery with standby time up to 450 hours and talk time up to 8 hours. It is available in black color.
