I was annoyed on the random updates of the applications on my phone Every time I connect to the internet. I wish it to stop, then I saw the download manager on my phone. I tried so force stop the updates. After that I can no longer connect to the internet. Please help! My phone is LG SU760.
LG SU760 can no longer connect to the Internet
Hi Kris, in order for you to get back the internet connectivity for your phone, you need to reset your APN or your Access Point Name in order for you to gain once more access to your internet. Just go to your Settings, then to More Networks then to Wireless & Networks or Mobile Data Networks. Then check your Access Point Names which must correspond to your internet service provider. You will receive a confirmation from your provider as soon as it is correctly configured.Â
