Library Folder is missing after installing OS X Lion
I installed OS X Lion Developer Seed, I found out that installing this may cause too many bugs so I re-installed Snow Leopard using the original DVD. But now, iPhoto, Aperture, JDownloader could not start. On my IGetter downloads break, The Airport does not connect automatically. Then I found out that the Library Folder is missing. I could not find it even in the Home folder and even when I do a Spotlight search. I know it is wrong to install beta software as an update instead of installing it to different partition. How can I go back to my original settings without issues? Help please.
