I am facing an error when launching MS Word. It failed and crashed with error
“Library not loaded: @rpath/mbukernel.framework/Versions/14/mbukernel
Referenced from: /Applications/Microsoft Word.app/Contents/MacOS/Microsoft Word
Reason: image not found.”
I tried to remove the suite and re-install it back but it did not help me resolve the issue. Please help me.
Library Not Loaded Error in MS Word
Hi. I have searched the web and came up with the following solutions. Hope that these will help you to overcome your problem.
Solution 1:
Check that whether your “Microsoft Word.app” file is in “/Applications/Microsoft Office 2011” folder. If its not in there it will be in “/Applications” folder. Drag this file into the above location. Then try to run the application again. Your application will run. This is a common mistake in mac OP.
Solution 2:
Try to uninstall any previous version of MS Office and then install again. Reinstalling might help solving the problem.
