Library.dll error while launching Holdem Manager
Please,
I need someone who can help me. Whenever I launch my Holdem Manager, it tells me that it cannot open a “library.dll.”
I get to thinking that maybe it got corrupted or something went wrong during an update.
I cannot launch the application without this file, can I?
Please help me fix this.
Table manager
Can’t open file C:program files (x86)RVG SoftwareHoldem managerlibrary.dll
Answered By 0 points N/A #181732
Hi Christian,
There could be a couple of things going on. The installation might somehow be corrupted, or it might be the Antivirus on your system.
As the first step, try disabling your antivirus software and see if the issue gets resolved. If that is the case, you need to open the list of blocked files from your antivirus' interface and remove the library.dll file.
If the above step does not work, search for the library.dll file from the Holdem installation cd or package and copy it over to the folder in which the Holdem installation files are stored on your computer.
