Peter A May
10 points
Posted on - 09/12/2013
After reboot my computer when I attempted to start LibreOfiice 3.5 an error message occurred saying “The application cannot be started”. It was working fine but now I can’t access this program. What happened to this program? Can I fix this problem ASAP? Please guide me properly. Thanks.
LibreOffice 3.5 – Fatal Error
The application cannot be started.
A file status object could not be filled.
Libre Office 3.5 – Fatal Error The application cannot be started
Hello Peter,
Running LibreOffice 3.5. may result in a runtime error on some Windows XP machines.
To solve this problem you have to install the current Microsoft Visual C++ 2008 Runtime on your machine.
1. Click on the link above
2. Click on the Download button to start the download
3. Click on Run to execute the installation file immediately after the download or click Save and install later by double-clicking the saved file.
Osborne Percival
