nicko stone
10 points
Posted on - 08/28/2012
I’m trying to install the latest version of LibreOffice using the Ubuntu Software Centre but it can’t find the correct files to install the program. This is indicated by an error message stating that LibreOffice can’t be installed even though it was downloaded and extracted.
Usually when I use the Software Centre to install software I am required to enter my password followed by a Authenticate or Cancel message box popping up but now regardless which option I choose I need to manually close the box and the software starts to install.
How can I stop these error messages so I can successfully install LibreOffice?Â
If you failed to download LibreOffice through Software Center you can install your LibreOffice through command prompt. Before install LibreOffice from command prompt remove LibreOffice is exist
sudo apt-get purge openoffice*.*
To install LibreOffice you can follow the below steps
sudo add-apt-repository ppa:libreoffice/ppa
sudo apt-get update
sudo apt-get install libreoffice
You may also required to execute below query
sudo apt-get install libreoffice-gnome
Hello Nicko,
As with the previous comment you can try to download and install it using the command prompt. But first be sure to remove existing LibreOffice files.
1. Open Terminal window Applications -> Accessories -> Terminal. Then follow the steps below.
2. sudo apt-get remove –purge libreoffice-core libreoffice-common
   sudo apt-get autoremove –purge
3. sudo apt-get install libreoffice
4. Complete the installation by including the Ubuntu (Gnome) desktop integration:
   -If you’re using Ubuntu (Gnome):
   -If you’re using Kubuntu (KDE):
      sudo apt-get install libreoffice-kde
Hope this solves your problem with installing LibreOffice. Feel free to ask if you have any questions.
Thanks
