LibreOffice Productivity Suite 3.5.4 Software
The latest software ‘LibreOffice Productivity Suite 3.5.4’, alternative of ‘Microsoft Office’ is becoming very popular. What are the requirements of installing it?
Windows
The software and hardware prerequisites for installing LibreOffice on a Windows system are as follows:
· Microsoft Windows 2000 (Service Pack 4 or higher), XP, Vista, Windows 7, or Windows 8;
· Pentium-compatible PC (Pentium III, Athlon or more-recent system recommended);
· 256 Mb RAM (512 Mb RAM recommended);
· Up to 1.5 Gb available hard disk space;
· 1024×768 resolution (higher resolution recommended), with at least 256 colors.
Administrator rights are needed for the installation process. It is a recommended best practice to back-up your system and data before you remove or install software.
Macintosh
The software and hardware prerequisites for installing on a Macintosh computer are as follows:
· MacOSX 10.4 (Tiger) or higher;
· Intel or PowerPC processor;
· 512 Mb RAM;
· Up to 800 Mb available hard disk space;
· 1024×768 graphic device with 256 colors (higher resolution recommended).
For certain features of the software – but not most – Java is required. Java is notably required for Base.
Linux
As a general rule, you are recommended to install LibreOffice via the installation methods recommended by your particular Linux distribution (such as the Ubuntu Software Center, in the case of Ubuntu Linux).This is because it is usually the simplest way to obtain an installation that is optimally integrated into your system. Indeed, LibreOffice may well be already installed by default when you originally install your Linux operating system.
The community-supplied LibreOffice installers are provided for users having special needs, and for out-of-the-ordinary cases.
Some Linux distributions ship with their own “native” version of LibreOffice, which may have different features from the community-supplied version of LibreOffice. In many cases, you can install the community-supplied LibreOffice alongside a “native” version. However, you may prefer to remove the “native” version before installing a community-supplied version. For details on how to do that, please consult the user help resources provided by your particular Linux vendor.
Please make sure you have enough free memory in the temporary directory on your system, and please ensure that read, write and run access rights have been granted. Close all other programs before starting the installation process.
The software and hardware prerequisites for installing on Linux are as follows:
· Linux kernel version 2.6.18 or higher;
· glibc2 version 2.5 or higher;
· gtk version 2.10.4 or higher;
· 256Mb RAM (512Mb RAM recommended);
· Up to 1.55Gb available hard disk space;
· X Server with 1024×768 resolution (higher resolution recommended), with at least 256 colors;
· Gnome 2.16 or higher, with the gail 1.8.6 and at-spi 1.7 packages (required for support for assistive technology [AT] tools), or another compatible GUI (such as KDE, among others).
Thank you
