Green Scott
50 points
Posted on - 10/21/2012
Hi fellows,
I was trying to install advanced systemcare v4.1.0 the other day but when I entered the license key, it ended up in an error.
The screenshot of the error is as follows:
Register
The license has been activated for maximum PCs and cannot be used. Please purchase another license to activate Advanced SystemCare Pro for this PC.
OK
Now can anyone please guide me what should I do to get rid of this error?
I have searched a lot for the solution but couldn’t find an authentic answer.
Looking forward to your replies
Kindest regards
License key for advanced systemcare v4.1.0
Hello Green,
It seems that you are using a pirated copy of the software. Using pirated copy of software could lead to potential damages to your computer. If you want to use the software, the better option is to buy a genuine copy of the same. You will get full customer support from the vendor side.
Hi, Green!
I'm afraid that you may not be able to install this program onto your computer anymore. The prompt states that it has already exceeded the amount of installs. You cannot get rid of this error, the only solution would be to purchase another license to be able to use this software.
