A license for MAC computers
Would I need a 2 license package for my Mac computers? I have a Mac Book Pro that I use when I travel and an iMac that I use when I’m at home. I only use computer at a time.
Do you mean Mac OS X license package? If its is, I guess you do not need to purchase two license package to run on each Mac PCs. Example is, when you purchase a copy of Lion, you are entitled to download, install, use it and run it on the entire Mac PCs that you own or control. This is according to the Mac's Software License Agreement (SLA).
If you have multiple Mac PCs, the easiest way is to just copy the OS X installation app that you downloaded from your primary Mac PC to your other Mac PCs. This installation app can be seen in the /Applications folder. Just look for Mac OS X Installer and then copy it on your second Mac PC and run the installer.
However, if your OS X comes from the Mac PC that you purchased, you are not allowed to use that copy of OS X as Mac App Store did not give you the license to install it on other Mac PC.
