Ivan Cruz
10 points
Posted on - 09/17/2012
Why am I getting an error “License verification cannot update my data and application” on my Kaspersky 2012? My license is not yet expired and has been using it for few times before this issue appears.
Can someone please help me?
License Verification Error on Kaspersky 2012
Hello Ivan,
To resolve the issue that you are getting, you will need to use the following procedure:
Open the Kaspersky interface and then go into Repositories and Licenses.
You will need to check the checkbox for install license automatically, and then save the changes.
After that restart Kaspersky and see if it will work well.
Hope this helps.
Carl
Hi Ivan,
The above mentioned way is very efficient way to solve this problem. Or, you can do another work. Please remove it and install it again. Then be registered with your license key.
Hope, your problem will be solved.
If this does not work, please contact with your software vendor.
