sammy noel
50 points
Posted on - 08/30/2012
Hi Experts,
Can anyone help me on deep clear download?I want that software to be downlaoded.Currently I am having trial version of it.I need license copy of it to install on windows 7.Does anyone know a web site for this other than cnet.com.Thanks.
Sammy Noel
Licensed Copy of Deep Clear software for Win 7
Hello.
To the best of my knowledge, Deep Clear software licensed version is not available on internet. But I suggest you to go for alternate software which are available freely and are more accurate than the deep clean software.
Thank you.
Maybe you are looking for some deep clean software to run in your system. You can try the CCleaner which is the best cleaning tool for your Windows PC. It allows you to clean the temp files, history, cookies and more in Internet Explorer, Firefox, Opera, Safari and Chrome browser. It can also help you remove unused registry entries. Also, you can try other software such as SpyBot Search and Destroy, Ad-Aware, and more.
