Licensing for this product has stopped working.
I am a home user, I have installed Windows 7 64 bits on my computer. I have installed Adobe CS4 to my system. 5 days before I used this application, no issue detected. Now whenever I open this application, I am getting below error message.
This product has encountered a problem which requires you to restart your computer before it can be launched.
Error: 148:3
https://helpx.adobe.com/support.html
What should I do if I want to use the Photoshop application?
I cannot get in touch with Adobe technical support.
Thanks for all suggestions…
