Light Leak in Asus TF101?
While examining my newly bought Asus Transformer i saw that the screen bleeds. It is way too much and I want to get it replaced. Is it feasible for ASUS to replace?
This problem is between the customer and the store where you bought your device. But of course, as what they always say, the customer is always right.
But sometimes they have the policy of not accepting a product return unless it is defective so I think you need to convince the store that the product you bought has a defect and you want a replacement for it.
In order for them to grant you your request and give you the replacement, you must first convince them and explain to them that the device is not abused and you use it the proper way when you noticed the problem.
They will never replace it if they found out that you mishandled the product which resulted to damaging it.
