Light room 4.1: Export warning started appearing after installing Microsoft Office
Hello friends,
I am using windows 7 64 bit on my PC with 6 GB ram. I have been using adobe photoshop lightroom 4.1 on my machine, and it was running perfectly but just yesterday I started facing an error after I installed the Microsoft office 2010 home student edition.
After its installation, when I try to export a photo, the photo is exported correctly but the following error pops up on my screen every time even if Microsoft office is not running. I have attached the screenshot of the error below:
The error says:
Unable to Export:
An internal error has occurred: Win32 API error 2 (“The system cannot find the file specified.”) when calling ShellExecuteExW from AgWorkspace.shellExecute
Can anyone please guide me what should I do to remove the error? I'll be really thankful for any kind of help and guidance.
Waiting for your reply
Kindest regards
Best Answer by Adish Pescadero
Answered By 0 points N/A #192459
Hi King,
 You are probably receiving this error because you left the "Post Processing" field blank. You are not receiving this for installing MS Office 2010. This has been an issue for a few times since LR4 beta.
Follow the steps below to resolve this issue:
1.     Click on "Post Processing". It should be below the "Export" panel.
2.     Select its default setting, which is "Do Nothing" or any other valid option.
3.     Restart Light Room 4.1.
Answered By 0 points N/A #192460
Hello King,
The error that you are getting simply implies that the "Post Processing" field that is at the bottom of the Export panel does not have any values (default should be 'Do Nothing'). Such an issue has been common a few times since the LR4 beta started. To  resolve it, you will simply need to enter a valid option and the error should disappear.
Nicke
Answered By 0 points N/A #192461
The issue is likely caused by an empty entry in your Post-Processing dialog box. This is a problem faced by many users who upgrade to LR4. To fix it.
1. When your Post-processing dialog box opens, notice a drop down menu  with "After Finish" next to it.
2. If you don't want to do anything after processing, choose "Do Nothing". Don't leave the field empty, as this is unacceptable (and is the likely cause of your error).
3. Proceed as you normally would.
Answered By 5 points N/A #192463
Hi King,
Side by side these solution you can also follow another way to solve this problem. To get that one visit this Techyv page.
An internal error has occurred Win32 API error 2
