Paul C Pina
50 points
Posted on - 02/18/2014
Hi there,
I got this weird error message when I am working in Adobe Lightroom. I do not have much knowledge about Lightroom. I am not getting the error message correctly. Is that says a document is empty? I have been working in the document for a week. What might be the root of this error? Please support to find the solutions. Thanks.
Can’t update this collection.
An internal error has occurred: Error
Domain— NSXMLParserErrorDomain Code=4 Line 1:
Document is empty
Userlnfo—0x11201f850
{NSLocalizedDescription = Line 1: Document is empty
OK
Lightroom LR 4.1 RC Flickr publishing broken
If you are in the process of exporting your photos or publishing your photos to Facebook using Adobe Lightroom, then you need to download and install the latest Lightroom plug-in from Export to Facebook Lightroom Plug-in. This Lightroom plug-in allows you to directly export your pictures to your Facebook account. See image.
This latest version will support Adobe Lightroom 2, Adobe Lightroom 3, Adobe Lightroom 4, and Adobe Lightroom 5. But if you are using an older version of Adobe Lightroom such as version 2, it is possible that some of the features available in this latest plug-in may be missing. This version works on both Microsoft Windows and Mac OS X so there is no problem downloading and installing it on either operating system.
For users running Adobe Lightroom 5.0 until Adobe Lightroom 5.2, you may encounter a major bug associated to Publish. If this happens, you need to upgrade to Adobe Lightroom 5.3 if you will be using Publish.
