LightRoom Plugin Enfuse Error After Formatting my Hard Drive
60 points
Posted on - 07/10/2012
I’m a Windows 7 user. I have installed LR4 and LREnfuse4.13. I’m getting this error when I run Enfuse. The program was functioning perfectly, but after I formatted the hard drive, I’m having problems. I was using an old version of LR before formatting.
The error message is: ”The application has failed to start because its side-by-side configuration is incorrect. Please see the application event log or use the command-line sxstrace.exe tool for more detail. ”
This error shows while trying to run the command: Program FilesAdobAdob Phtoshop Lightrom 4Plug-innsLREnfuse.lrpluginbinenfuse_openmp.exe" –o
Please help me find the solution.
