Modern design of computer hardware takes into account on designing of systems that can work very fast hence the need of having many processors with the computer. what are the limitations of having more than one processor within a computer system?
Limitations of a computer having many processors
The processor is a group of transistors which have to connect and disconnect during a process. While they are doing so, there is the generation of heat. Having more processors in a machine than it recommended means that there will be more heat generated. High heat levels cause the processor to shrink resulting to speed limiting.
The processor is a group of transistors which have to connect and disconnect during a process. While they are doing so, there is generation of heat. Having more processors in a machine than it is recommended means that there will be more heat generated. High heat levels cause the processor to shrink resulting to speed limiting.
