Link for a compaq bios download
I need to update my hp Compaq BIOS.
Is there any link where I can go for a Compaq bios download or can I do it when my windows boots up.
Hi Alland,
I am also using an HP Compaq and have successfully updated my BIOS on several occasions.
The process is simple but only if you know how to do it.
But if it's your first shot, then I would suggest not to hurry but to go step by step as it will help you to learn and do it safely and perfectly.
I am giving you a link here where you can find all the details to update your BIOS step by step.
Just follow the instructions properly and I hope it will be done. Here is the link
Hope it helps.
