Link to download the utility for testing of memory card
Hi all, is there any one who knows any link where I can download the utility for testing of memory card actual transfer rate?
Hi, Asheley Madison
As you know, from Google you can find a lot of forums but the chance of getting the right solution depends on where you post your problems. We have so many different forums to download the utility for testing of memory card.
So classifying and posting them on relevant forums is the best way to get your answer step by step. I can suggest you some good forums, which are listed below:
1. https://filehippo.com/download_teracopy/ (just download and use it).
2. http://www.fileguru.com/Speed-Test/download.
Hi Ashley Madison,
You can check the label on your card, it will say something like class 4 or class 10 SD card. The manufacturer already did a pre-test on their card before selling it on the market, but if you want to check the actual speed of your card, try these programs:
Card Speed 1.0 – This will test the reading and writing speed of your memory card.
Storage Tools 2.2 – This has many more functions besides reading the actual speed of your card. It can also partition and format your SD card. You can find both of these programs on softonic.com.
https://en.softonic.com/s/speed-test-memory-card:pocketpc
Thank you,
Adrian Leano
You might try this utility, Digital Media Doctor.
https://www.lc-tech.com/pc/digital-media-doctor/
