My friend is asking if he can link his Outlook to his desktop PC and laptop so he can still access his email even when he’s not at home. He doesn’t have an account yet and he is using Yahoo for sending and receiving emails. The problem is, when I try to enter his information and create a new account for him, it tells me that his email address already exists. How can I fix it and how can I sync Outlook on his desktop PC and laptop? Any suggestions please. Thanks.
james86
Link MS-Outlook to Desktop PC and Laptop
Hey
You can have the same account on two different machines, ever done it before,but not with yahoo. I don't think it's different
Do not add the same account on one computer
But I would do it manually by installing outlook in the both machines, creating accounts in both, then copying the outlook.PST file from one to the other.
For mail synchronization, there's some tools/software for that.
You can check out https://www.simplesyn.net/en-US
This is very easy to do. Simply follow the instructions.you have to do it on both of the computers.
Go to MS Outlook Accounts and Add new email Account. Go to manually configure and create a POP3 accounts.
Now enter all these settings in SMTP and POP. Add your own username and password.
Go to more settings and click advanced. Enter following port settings in POP and SMTP.Remember to check leave a copy of the message on the server.
Also in Outgoing Server option check on Require Authentication tab.
