Dear Techyv Friends,
I need a small support from my Techyv friends, Please do the needful for sending me the link towards NetApp Sharepoint Calculator, that will generate the estimate storage requirements using an efficient IT calculator based on the Capacity Requirements & Annual Growth Rate. Please sne me the link towards the mentioned portal asap.
Thanks,
Garrick Sanderford
Link towards NetApp Sharepoint Calculator
Hello there Garrick,
Thank you very much for trusting techyv. I have read your question. Here is the link that you wanted.
I hope that I could help you and give you a proper solution. If you have any other problem then free to ask us.
Thank you.
Berta R Cahill
Hello Garrick Sanderford,
I think can help you with your search for NetApp Sharepoint Calculator.
I recommend this software – Netapp System Manager downloadÂ
The software is a simple powerful management tool – easy to use and efficient, very good solution.Â
Advanced storage features: SnapMirror, SyncMirror, SnapLock, vFiler, Vservers and much more.
Thank you!
Nathan H Underwood
