Linking error with BDE Table Paradox in MS Access 2007
I was using Access 2002 and now migrated to Access 2007. Usually I am importing two files to Access from Paradox 4.5 in which one file is having ‘ASCII’ and one file is having ‘International’. I don’t know why both are different even if it seems like the same. The problem is I have to manually change anyone by using registry edit. If it is not done, an error message will pop up which displays that ‘Unexpected error occurred from external database.’ The error code is 11265. I have no idea why this is happening. I have doubt that it is happening because of user permission. Please help me to get solve this problem. I will thankful be for all help and support.
