michaeltaas
Posted on - 09/03/2011
Linking fails on Red Hat Enterprise Linux 4 U2 or greater.
I installed Oracle 10g on Window XP, it works for me. Now I want to install this software on Windows Vista but I receive the below error.
Error of detail is given below for your understanding.
Error
Error in invoking target ‘relink’ of makefile
‘/opt/oracle/app/oracle/product/10.2.0.1
/asm/precomp/lib/ins_precomp.mk’. See
‘/opt/oracle/app/oracle/oralnventory/logs/installActions2006-
12-28_12-15-06PM.log’ for details.
Click ‘Help’ for more information.
Click ‘Retry’ to try again.
Click ‘Ignore’ to ignore this error an go on.
Click ‘Cancel’ to stop this installation.
Help Retry Ignore Cancel
When installing Oracle 10G on Windows Vista, computer should be compatible with the version you're installing.
Check all system requirements before you proceed with the installation.
Type the type of components you have, hardware, software and available memory space. You should use 10.2.0.5 patches or higher must be used to install this software successfully if not, then you'll be having trouble doing the installation.
The certification matrix should be active because Microsoft will validate the key upon installing the software.
This certification Matrix is provided by your vendor of that software in the form of CD.
This CD has the certification key inside it. Use this valid certification key to install the software.
You can visit support oracle com to see the full instructions on how to install the software.
