Hello techyv.com!
My laptop here is an Acer laptop and its OS is Windows 7, Now I have a job of researching many websites through the internet and I was asked to bookmark each of those important ones. I've seen in the internet about linkman 8 but it is for sale, So what makes linkman 8 better than those default bookmarks in my browsers? Thanks!
Is linkman 8 worth it to buy for bookmarking?
Hello
If you are needing to save a lot of bookmarks about a lot of different web sites then it can become really confusing very quickly as you can't organize bookmarks very well with the default bookmarking options in the browsers.
Linkman is fully compatible with all the major browsers such as Firefox, Explorer, Safari, Opera and Chrome.
Linkman can save all your bookmarks in an XML document that can be easily backed up in case of a computer failure.
Linkman also syncs all the bookmarks between the different browsers and can also sync between multiple computers/
If you don't have access to your computer but want to carry on working on another computer Linkman can be saved on a USB drive and used anywhere.
Hi there Ridge Wayaden,
Linkman is an awesome bookmark manager that can handle quite big bookmark databases. Another thing about it that it works great with all popular browsers.
Still, the best way to check if it is worth buying for you is to try it. OuterTech, the developer of Linkman, is offering two versions of the software – lite and professional. The main difference in those two versions is the number of bookmarks you can store – lite version is allowing you to store 2×5000 bookmarks, while pro version is offering unlimited number. Other differences are mostly graphic, like storing web page icons with the links and keyword features.
Best regards,
Drake Vivian
Hi Ridge,
Linkman Pro is a bookmark management solution which supports 10 different browsers and integrate with Firefox, Internet Explorer, Opera, Chrome and Maxthon. Linkman compared to an ordinary default browser has many features. Linkman has a link checker tool that can check bookmarks for deadlinks, content changes and page movements. You will be able to know which links are dead and which sites have moved. Furthermore, separate colors will be assigned to each. Its link checker is capable of updating URLs of links that have moved to the address of the new location.
