anonymous
7060 points
Posted on - 08/11/2011
Hi!
I am new computer user.
For proper defense of my computer I require House Call Antivirus. But I do not know where to download this Antivirus.
Now I require the downloading process of this Antivirus.
This is more essential for my computer defense.
Smith1
Links and Downloading Process of Trend Micro HouseCall Antivirus
Yes! you are right. Antivirus program is very essential for every computer to avoid problems and its very easy for you to download HouseCall Antivirus system to your computer . Just follow the simple procedures.
First you will have to open your internet explorer, there you should type or just simply click this URL and the new window will appear.
You will click on the link Download Housecall 7.1 (32-bit) or (64-Bit) as per your windows 7 requirements you can download it and after downloading the program you will have to run setup and update the program with built-in feature in this program.
Hope this will work for you
Yes antivirus programs Is very important for any computer and it plays a good role in protecting your computer programs. You can download any of your desired antivirus from Network and it is easy. You need to go to the website you want to install antivirus and then download antivirus program from that website. Once you have download the antivirus program then you can install it properly on your computer. It is easy and accurate way to protect your computer.
You can also buy a new antivirus from one of antivirus software provider website and it will work more accurately as it contains more protection to your computer programs. Once you have installed antivirus program run a full scan to your computer to make sure that you are fully protected and there is no virus in your computer.
