Links for Flash 11 offline
HELLO !
I need your help about flash 11 offline. Can anyone provide me a link for flash 11 offline installer ? And currently I am using flash 10 but I heard that flash 11 comes with great improvements so kindly anyone mentioned me what are the improvements ?
Best Answer by Flinder Matthew
Answered By 0 points N/A #142266
Hi
There are various sites offering adobe flash player 11 that can be downloaded for free. You can try and download this adobe flash player or adobe flash 11 in this site: http://download.cnet.com/Adobe-Flash-Player/3000-2378_4-10001055.html This Adobe Flash 11 version gives improved high-resolution bitmap support for faster and better videos and graphics. Hope this helps.
Answered By 10 points N/A #142267
Hi Fidelgiancarlo,
Adobe Flash Player Support Center provide the latest version of the flash software for free download.
Flash Player 11.7 is the latest version which overcomes critical vulnerability problems.
Here is the link to download the most recent version of Adobe Flash Player.
http://www.adobe.com/support/flashplayer/debug_downloads.html
Answered By 590495 points N/A #327171
If you need to install Adobe Flash Player 11, I don’t think it is still recommended to use this version because it is too old. Modern websites nowadays that use or display flash contents might not work properly if you install version 11. The version you need to install is the latest. Download the following and install on your computer:
If this doesn’t work, you need to update your web browser to the latest. For Firefox, go to the Mozilla Firefox homepage and download the latest. For Chrome, go to Google Chrome download page and get the latest version. This link downloads the standalone installer. For Opera, go to Opera for PC and download the version for your operating system.
With regards to the use of Adobe Flash Player, Adobe announced in July 2017 that they will be ending support for Flash Player by the end of 2020 and continued to encourage the use of open HTML5 standards in place of Flash. Microsoft announced in September 2019 that Flash will be completely removed from all web browsers on December 31, 2020 via Windows Update.
