Links For 32 Bit ITunes For Windows 7 Download
I want links to download 32bit iTunes for Windows 7. I am not finding a version for 32bit Windows 7 and I have tried to looking for it. Most of them were with malwares that affected my PC. Please help me.
Best Answer by Sharath Reddy
Answered By 90 points N/A #300722
I suggest you to download iTunes 32 bit for Windows 7 from the official Apple website as this will guarantee that the will be no malware or virus with it. It has a very good piece of software for streaming purpose and has a lot of good quality content. The file size is around 110 MB in download size and you can also mail the download link if you want to.
https://googleweblight.com/i?u=https://support.apple.com/kb/dl1614&grqid=XY3ucj3C&hl=en-IN
Answered By 590495 points N/A #302180
If you need to download the 32-bit version of iTunes for your Windows 7, go to iTunes Download to get the latest version from the official Apple website. The page automatically detects your operating system and your machine’s architecture and will show you the download appropriate for your computer.
Don’t try downloading and installing iTunes from any other website to avoid getting a modified version. When downloading iTunes, versions vary depending on your operating system. If you have Windows XP or Windows Vista either 32-bit or 64-bit, you will be downloading iTunes 12.1.3. Since both operating systems have been unplugged from Microsoft support, it seems this is the latest and last version of iTunes for these two.
If you have Windows 7 or higher either 32-bit or 64-bit, you will be downloading iTunes 12.6.2.
