Links For Windows Vista Theme For XP Download
I am looking for links to download Windows vista theme for XP to use it on my PC running Windows XP because the it looks nice to use. Please someone give me links to download it. Thank you.
Given below is a mini to download the Windows vista theme for your PC running Windows XP. It is really good in look and feel wise and looks 100%genuine vista like. The link had both the blue and the dark black vista theme available for download. After downloading , you need to extract the zip file and then you can use it. The download is free of any malware.
https://googleweblight.com/i?u=http://www.askvg.com/vistavg-ultimate-theme-for-windows-xp/
I also have Windows XP and until now I still use it. I also have lots of themes for Windows XP like Mac OS X, Windows Vista, Windows 7, and others. Basically, you can easily download different themes for Windows XP and you can find them almost anywhere on the web.
Since you want Vista themes for your Windows XP, have a look at VistaVG Themes for Windows XP. I also have this one on my computer. This theme has three versions: Windows Vista Ultimate, Windows Vista Blue version, and Windows Vista Dark Black version. If this is the first you will install a theme, try following the instructions indicated in the download page.
But basically, to install a theme, you simply need to copy the theme folder and the theme file (*.Theme) to “C:\WINDOWS\Resources\Themes” and the theme is automatically detected. But of course, since this theme is not from Microsoft, the theme will literally not work. To make the theme work, you need to install UxStyle. It requires Microsoft .NET Framework 3.5 Service Pack 1.
