Linksys router with error code 321, please help
Hi, when I was trying to install the Linksys Router in my hp laptop using CD I received a problem saying Error code 321. I contacted with some technicians but they couldn’t give me any solution. Please supply me with some help to solve this boring problem. Thanks
Answered By 0 points N/A #152401
Of add increase on the website. When the users visit the website and click on the Advertisement then $1 or $2 transfer to your account. This is the normal rate of the market that whenever user visit and click on the advertisement you will get $1 or $2. Investment Require for this Business: Website business require very small amount of investment like just creating the website. To create the website two things are required: Web Hosting. Domain Name. The space on which website data save is called Web Hosting. This space can easily purchase and available online.
Answered By 590495 points N/A #302309
Since you are installing the PC software for your router, you should check first if your computer meets the requirements. You can check the system requirements of the application from the manual that comes with your router. You can also check the CD for a PDF file that might contain the specifications and requirements of the router and the software.
One possible cause of the error is a missing component that you forgot to install like .NET Framework before installing the router software. If your router’s PC software requires .NET Framework, try downloading one of the following:
