HI guys,
I have recently started using Linksys wireless adapter but I am having a few issues with it especially in searching for new networks and in managing connections by establishing and terminating a connection.
What I want is assistance on how I can access the Linksys wireless manager tool so that I can make the proper configurations on my adapter, thanks guys.
Linksys software wireless adapter help
Hi Avery,
To access the Linksys Wireless Manager, look for its icon in your system tray.
If you are connected to a wireless network, you will see an icon with green bars just like this one –Â
. The green bars indicate the strength of the connection with the wireless network.
If you are not connected to a wireless network, you will see an icon with a red x on it, just like this one –
Once you have located this icon, just click on it and then select View Wireless Networks.
To close the Wireless Manager, click on the Linksys Wireless Manager and select close.
If you want to know more, you may go to this link.
