Linux Active Directory Domain Controller. Domain Active Directory.
Domains with active directory ensure that the administrator has security and is able to have experience o any computer they login. The products of Microsoft for such purpose can be expensive for small business domains. Describe aboutthe Linux active directory domain controller.
Answered By 40 points N/A #92592
SAMBA SOFTWARE
–>Switch on the PC you want to use as a domain controller.
–>Install Linux:
–>Insert the DVD into the DVD drive. Enter when the screen displays.
–>RHEL installer will be displayed. It will check if the CD is correctly working. Click on Skip.
–>Choose the language according to your preference.
–>Choose the keyboard type according to your preference.
–>If you have an installation number on the License the enter it or else skip the step.
–>Click on the ‘review and modify portioning layout’. It will create partitions.
–>Click on new.
–>Select any partition.
–>Create swap, home, boot etc. partitions.
–>Press on next.
–>Click on next.
–>Select the Ethernet devices to use the network connections.
–>Choose the time zone.
–>Enter the root password. Then click on next.
ð  Click on customize later.
–>To start the installation press on next.
–>Reboot your computer.
–>Accept the License agreement and then click on forward.
 Fill the further information like time zone, user account. You have installed Linux.
Install the DHCP Server.
  •  Open the start menu.
  •  Click on the Administrative Tools.
  •  Go to Server manager and then user account control.
  •  Under ‘Roles Summary’ click on add roles and then next.
  •  Check the DHCP Server.
  •  You have installed DHCP Server.
–>Install the BIND9 DNS Server.
–>Install the SAMBA software and then configure it.
–>Make the user account.
  • Create a samba account also. This account is the default one i.e. the administrator.
  • Enable the Roaming profile settings.
  • You are ready to move and use the domain controller.
